July 5, 2017, 04:39 |
bed elements on a curve
Przemek
Rep Power: 15 |
Hi All,
Can anybody help me how to avoid such bad elements in the circular curves shown in the attached figure? There is a curve for sure because I created it manually.
best regards pblasiak Last edited by gaza; July 5, 2017 at 04:41. Reason: forgotten attachement |
July 5, 2017, 10:40 |
#2 | |
alur
Rep Power: 8 |
Give mesh, try to help you. metalist93@gmai.com |
July 8, 2017, 03:17 |
Przemek
Rep Power: 15 |
Ok I found that there was two curves (at the surface intersection) and each of them belonged to the other surface (they appeared after extract curves from surface command). I had to delete one of them and now it is OK.
best regards pblasiak |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
meshing of a compound volume in GMSH | shawn3531 | OpenFOAM | 4 | March 12, 2015 10:45 |
[ICEM] Bad quality surface mesh elements at curve | benjaminhogan | ANSYS Meshing & Geometry | 8 | December 13, 2014 15:03 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
