July 25, 2017, 09:21 |
mesh warning fix
Valentin Iulian GEAMANU
Rep Power: 8 |
Hello
I'm newbie in art of meshing. Can you tell me how can i fix this warning? At global mesh i put Use Advanced Size Function: On: Proximity and Curvature Relevance Center: Fine Initial Size Seed: Active Assembly: Smoothing: Medium Transition: Slow Span Angle Center: Fine Use Automatic inflation: Program Controlled - Smooth Transition Transition Ratio 0.77, Max Layers: 5, Growth Rate 1.1 Collision Avoidance: Stair Stepping Patch Conforming Option - Triangle Surface Mesher: Program Controlled The others are default http://imgur.com/a/pML4Y http://imgur.com/a/fhvHi Thank you . Last edited by valentin.geamanu; July 26, 2017 at 03:31. |
Display Modes | |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
