[ANSYS Meshing] mesh warning fix
Old   July 25, 2017, 09:21
Default mesh warning fix
Valentin Iulian GEAMANU
valentin.geamanu is on a distinguished road
Hello
I'm newbie in art of meshing. Can you tell me how can i fix this warning?
At global mesh i put
Use Advanced Size Function: On: Proximity and Curvature
Relevance Center: Fine
Initial Size Seed: Active Assembly:
Smoothing: Medium
Transition: Slow
Span Angle Center: Fine
Use Automatic inflation: Program Controlled - Smooth Transition
Transition Ratio 0.77, Max Layers: 5, Growth Rate 1.1
Collision Avoidance: Stair Stepping
Patch Conforming Option - Triangle Surface Mesher: Program Controlled
The others are default
http://imgur.com/a/pML4Y
http://imgur.com/a/fhvHi
Thank you .
valentin.geamanu is offline   Reply With Quote
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
