August 10, 2017, 06:14 |
Meshing Solid Cone
Nurzhan
Rep Power: 12 |
Dear ICEM experts,
Could please advise me about meshing a complex geometry, which is a solid cone inserted into a section of a solid cylinder (as shown in the below attachment)? The cylinder and cone are split into two parts, so there are four domains, each has unique properties (rho, k, and Cp). I would like to use the mesh to model heat transfer inside this geometry in ANSYS CFX. I am inexperienced in ICEM CFD, though I tried to mesh the geometry using the software (as shown in the attachment). The results obtained using my mesh indicate that there near the cone. I will appreciate your advice! Sincerely, Nurzhan |
[ANSYS Meshing] 3D Cone Meshing | molek | ANSYS Meshing & Geometry | 2 | June 3, 2017 14:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[ICEM] Tetra meshing fluid and solid regions separately in ICEM | znri | ANSYS Meshing & Geometry | 0 | September 27, 2014 06:37 |
[ANSYS Meshing] Meshing for flat plate immersed solid | hamed.majeed | ANSYS Meshing & Geometry | 0 | July 10, 2012 13:32 |
