[ICEM] ANSYS ICEM 2 fluid region for 2D problem |
September 25, 2017, 06:58 |
Rep Power: 8 |
Dear Guys,
Could any one pls tell me how to create two fluid region for 2D mesh? I have created the mesh using "Block" and name it "Fluid" I have tried to split the block into half. But when i finished computing the mesh, they are still only one fluid region when imported to Fluent. And, I have also tried to create another new "Block", however, each time it will reset everything and remove the old block. |
September 25, 2017, 16:22 |
Gwenael H.
Rep Power: 20 |
This is an easy fix. You’re nearly there, once you’ve split the fluid blocking into 2 you need to create a new part (rmb on parts > Create part -> change filter to “Blocking material”) and assign one half block to it. This will allow you to have 2 regions when importing it in Fluent. Have fun |
September 25, 2017, 21:59 |
Rep Power: 8 |
Thanks so much Gweher!
It is working now! : ) |
September 26, 2017, 02:02 |
Gwenael H.
Rep Power: 20 |
You're welcome
icem 15, meshing 2d, meshing advice |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 03:17 |
Ansys 14.5 Problem Import Mesh from ICEM CFD to CFX | Smiling Assassin | CFX | 1 | May 9, 2014 02:27 |
how to contact multi fluid region in ansys DM | oilsok | ANSYS Meshing & Geometry | 1 | January 14, 2011 17:06 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
