September 19, 2017, 07:35 |
O Grid Is Not Successful!
Dear all,
Hello. Hope all are well. I am facing a problem in generating an O grid for parabolic trough collector (PTC). The solar collector has an inner cylinder that is fluid, an outer concentric cylinder for metal pipe, a third cylinder for vacuum which I have currently selected as a fluid and a fourth cylinder for glass pipe. I have four cylinders in design modeler that are also in ICEM. I created a block for the whole geometry (getting a "SOLID" part), associated block edge to geometry curve of outer most cylinder i.e. glass pipe, and snap vertices. But when I try to create an O grid using faces of inlet and outlet I get an error "O grid not successful". Why is that? I have tried o grid blocking through block method as well but same issue is there. Would be grateful if someone could help me out. Thanks. |
September 20, 2017, 04:21 |
Hello guys. Would be grateful if someone could help me out. Thanks. Ghizlani M. Ali, Glenn Horrocks, H. Gwenael, Philipp, Sebastian Engel, Shereez, Sigal, Sumeet Kotak or any experienced guy. Thanks.
Fluent LES model: grid requirement? | dinhanh | FLUENT | 1 | November 11, 2015 12:15 |
How to make grid for LES simulation | dinhanh | Main CFD Forum | 3 | November 11, 2015 02:37 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 22:26 |
