[ICEM] ANSYS ICEM 2 fluid region for 2D problem
Old   September 25, 2017, 06:58
Question ANSYS ICEM 2 fluid region for 2D problem
calvinlai is on a distinguished road
Dear Guys,
Could any one pls tell me how to create two fluid region for 2D mesh?
I have created the mesh using "Block" and name it "Fluid"
I have tried to split the block into half. But when i finished computing the mesh, they are still only one fluid region when imported to Fluent.
And, I have also tried to create another new "Block", however, each time it will reset everything and remove the old block.
calvinlai is offline   Reply With Quote
Old   September 25, 2017, 16:22
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
This is an easy fix. You’re nearly there, once you’ve split the fluid blocking into 2 you need to create a new part (rmb on parts > Create part -> change filter to “Blocking material”) and assign one half block to it. This will allow you to have 2 regions when importing it in Fluent.
Have fun
Gweher is offline   Reply With Quote
Old   September 25, 2017, 21:59
Thanks so much Gweher!
It is working now! : )
Old   September 26, 2017, 02:02
Gweher's Avatar
Gwenael H.
You're welcome
icem 15, meshing 2d, meshing advice
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 03:17
Ansys 14.5 Problem Import Mesh from ICEM CFD to CFX Smiling Assassin CFX 1 May 9, 2014 02:27
how to contact multi fluid region in ansys DM oilsok ANSYS Meshing & Geometry 1 January 14, 2011 17:06
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
