[ICEM] ICEM CFD Segmentation violation CentOS 7.3 |
September 28, 2017, 15:08 |
Brian
Rep Power: 8 |
I installed Ansys 17.2, 18.0, and 18.2 ICEM CFD on our CentOS 7.3 based cluster as individual modules. Every time I try to start ICEM CFD on any version I get the following error:
Missing font family helvetica Window information: depth = 24 class = 4 visual depth = 24 class = 4 can't load font screen14, using variable Signal 11 caught! segmentation violation - exiting after doing an emergency save Exiting... Exit from ICEM CFD |
June 25, 2018, 02:12 |
Rep Power: 10 |
hi there, have you solved this problem? I have the same problem recently
June 25, 2018, 04:18 |
Sebastian Engel
Rep Power: 20 |
although cent os differs alot from ubuntu, there have been similar issues with ubuntu. It might provide a hint to solve this issue: Error When Starting ICEM CFD in Ubuntu Ubuntu: cannot edit any field Best regards, Sebastian |
July 17, 2018, 21:58 |
problem solved
Rep Power: 10 |
i solved this problem by installing the rpm xorg-x11-fonts-misc.noarch.
you can use the commander below yum install xorg-x11-fonts-misc |
#5 | |
Rep Power: 10 |
November 23, 2019, 09:03 |
balaji
Rep Power: 10 |
same is coming for me i tried every cmd mention abover and also i installed "xorg-x15-fonts-misc"
after that i got same problem how to clear it |
November 24, 2019, 13:08 |
#7 | |
Sebastian Engel
Rep Power: 20 |
Why is the problem the same as the OP after you applied the previous solution attempts? |
[ICEM] Icem CFD on Linux | mechanicaldesign | ANSYS Meshing & Geometry | 7 | March 11, 2021 19:44 |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Using ICEM CFD to repair/edit ANSYS Meshing | Kaaji1359 | ANSYS | 2 | July 30, 2013 10:28 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
Importing Solidworks part into ICEM CFD | MetalSupremacist | FLUENT | 0 | October 8, 2010 17:46 |
