-   ANSYS Meshing & Geometry (https://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] how to deal with unavoidable high skew cells (https://www.cfd-online.com/Forums/ansys-meshing/193614-how-deal-unavoidable-high-skew-cells.html)
vipulramk September 29, 2017 03:49
I have 3D conjugate heat transfer problem with around 5 crore cells, I am having a condition where few cells are having a skewness greater than 0.98 (~4000 cells), I am in a situation where I cant improve the mesh since I have "RAM" restrictions. I am presently using RNG K-epsilon, enhanced wall function turbulence model. I have observed that in these cells my turbulence model is unable to converge and producing misleading velocity results.
but my energy equation is has reached stability with an error 1e-6 very early during the simulation (around 50 iterations) can someone shed some light on how to tackle this problem?
Also, I am using ANSYS Fluent to solve and the geometry is an Electric motor and is quite complex.
Thank you.
plucas October 2, 2017 12:22
I would look into maybe a cloud solving solution where you can get a better mesh like Nimbix
vasava October 6, 2017 05:40
I recommend the following:
  1. Convert mesh to polyhedral. This should significantly reduce number of cells.
  2. Use fluent commands to remove mesh anomalies.
  3. Make a simpler and coarse mesh. See if everything works ok. If so then make a finer and complicated mesh.
