[GAMBIT] Fatal error in gambit 2.2.30
Old   October 11, 2017, 07:17
Default Fatal error in gambit 2.2.30
Francesco L. Romeo
FrancescoLRomeo is on a distinguished road
Send a message via Skype™ to FrancescoLRomeo
I would like to use the software "Gambit 2.2.30" by Fluent Inc. for generating meshes in CFD, and I have experienced some problems which don't let me use this software.
First of all, when I open the Gambit Startup, I see these warnings:
Please try to start Exceed manually before you run Gambit.
Using X_DEVICE_DRIVER with standard visual.
Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-medium-r-normal-*-*-120-*-*-*-*-*" to type FontStruct>.
Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-bold-r-normal-*-*-120-*-*-*-*-*" to type FontStruct>.
Received X Intrinsics Warning <Cannot convert string "-adobe-courier-medium-r-normal-*-*-120-*-*-*-*-*" to type FontStruct>.
Received X Intrinsics Warning <Cannot convert string "-adobe-courier-medium-r-normal-*-*-120-75-75-*-*-*" to type FontStruct>.
Then, when I try to generate a simple 2D triangular grid, I get the fatal error that I attach in the image .
Thank you for any support,
Francesco
P.S. I get the same error both in a Windows 7 Professional and in a Windows 10 Home computer. For example, when I launch the file "C:\\Fluent.Inc\ntbin\ntx86\sysinfo.exe" in Windows7Pro I get the image that I also attach.
FrancescoLRomeo is offline   Reply With Quote
GAMBIT Fatal Error MrReElmo FLUENT 13 August 29, 2013 00:08
How to open a saved Gambit File? barkan FLUENT 5 September 1, 2012 05:53
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 10:26
