[ANSYS Meshing] Error in Meshing
Like Tree1Likes
  • 1 Post By Rudolf Diesel
Old   October 17, 2017, 20:00
Default Error in Meshing
Rudolf Diesel
Rudolf Diesel is on a distinguished road
Hi Everyone!!
I'm trying to analyse a combustion chamber in ANSYS Fluent 18
I have a problem mesh writing.
When I click the "Generate Mesh",ANSYS says this error:
・A mesh control is not associated to any geometry.
Project>Model>Mesh>Sweep Method (Chamber-Top)
Project>Model>Mesh>Sweep Method (Piston-Inflation)
Project>Model>Mesh>Sweep Method (Piston-Inner)
Project>Model>Mesh>Sweep Method (Chamber-Bottom)
I already tried to remake the engine model,but i get a same error.
This is the error which i got.
https://ibb.co/b4bfRR
How can I resolve this error?
Can anyone help me?
Thank you!!
Rudolf Diesel is offline   Reply With Quote
Old   October 18, 2017, 04:39
Baris PULAT
bpulat is on a distinguished road
Did you define your Source and you are still getting this error ? Src/Trg Selection is set to Manual.
bpulat is offline   Reply With Quote
Old   October 18, 2017, 21:40
Rudolf Diesel
Thank you for reply.
I defined source,but I still get error.
https://ibb.co/eru0d6
I think I have some problems in engine model which I made in SolidWorks.
Because when I used the engine model without piston bowl,I don't get error.
https://ibb.co/g5QsQm
Old   October 19, 2017, 04:47
Baris PULAT
When you right click the Mesh -> Show -> Sweepable Bodies you can see the problematic geometry.
What i would do in your situation is first, i will define the geometry which is not sweepable and what is causing the problem.
Then either i fix it in 3D modeling or i would use Virtual Topology in ANSYS.
Another suggestion is that using multizone the part that you can't sweep.
Hope it helps.
Old   October 24, 2017, 05:13
Rudolf Diesel
I am so sorry for late reply.
I am glad to inform you that the problem is now solved.
Thank you so much.
bpulat likes this.
Old   July 12, 2019, 02:15
Question
Hitesh
Hitesh12 is on a distinguished road
Thank you so much.
How were you able to solve the problem?
Hitesh12 is offline   Reply With Quote
Old   November 27, 2019, 01:52
xtanvi is on a distinguished road
How did you manage to solve the problem ?
xtanvi is offline   Reply With Quote
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 12:38
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 06:09
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
