[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file"
Like Tree6Likes
Old   September 5, 2012, 13:38
Default Error in Workbench "Unable to attach to geometry file"
Jeremie84 is on a distinguished road
I’m trying to use ANSYS Workbench 12.1 for CFD applications. First I import the geometry file (.stp). Then I right-click on Mesh to update or refresh, but I keep having this error message: “Unable to attach to geometry file”. I have the same error if I open Meshing after importing the geometry file.
I tried to find similar posts on the forum but I couldn't find something.
Thank you very much
Jérémie
Jeremie84 is offline   Reply With Quote
Old   September 5, 2012, 13:44
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
try another format like iges...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   September 5, 2012, 15:03
I tried with iges format, but still the same error message "unable to attach to geometry" when I try to open Meshing or update in WB.
Old   September 5, 2012, 15:09
diamondx's Avatar
Ghazlani M. Ali
what software did you to make your geometry ?
Regards,
Ali
Old   September 5, 2012, 15:13
SolidWorks
Old   September 5, 2012, 15:15
diamondx's Avatar
Ghazlani M. Ali
hmm it should not be a problem... you can import directly part file file of solidwork in designmodeler, try it ! i can't verify your file since i dont have access to solidworks here...
Regards,
Ali
Old   September 7, 2012, 14:40
Hum... I tried with a simple geometry (a 3D pipe) created directly in DesignModeler. But when I open Meshing, I have this same error message : "Unable to attach to geometry file".
I read something on the Internet about Internet Explorer settings, but I'm not sure... Could it be related to the installation of ANSYS? Or the license? though all the other ANSYS software (DM, ICEM CFD, Fluent) are working correctly on my computer.
Thank you very much
Jérémie
Old   September 7, 2012, 14:53
diamondx's Avatar
Ghazlani M. Ali
Ok, apparement parler avec Ali au téléphone n'a servi a rien
How about you attaching your file. i can take a look at it. see if i can troubleshoot the problem.
Regards,
Ali
Old   September 7, 2012, 15:05
What a small world...
Thank you Ali
Jérémie
Old   September 7, 2012, 15:25
diamondx's Avatar
Ghazlani M. Ali
that is in fact weird. i could load your geometry in ansys meshing without any problem.
i even could see your error. after i double clicked to try, it worked. I googled that and some say that it may be an error due to the installation of ansys: it has to be done under administrator rights.
In one forum i did found some directions:
I solved it (I built up the geometry in the DesignModeler, and the Mechanical Model didn't start. Error message: "Plugin error: Geometry interface not found" ). The solution:
1. Run the "CAD Configuration Manager 12.1".
2. Mark the "Workbench and ANSYS Geometry Interfaces"
3. Press "Next" button.
4. Press "Display Configuration Log File" button
5. Press "Configure Selected CAD Interfaces" button
6. Press "Exit" button
Run the Workbench, and it works.
HZs
the CAD configuration manager is in start menu under the ansys 13 branch, I wish i can help more...
MDB, JAISE15 and H.R.D. like this.
Regards,
Ali
Old   September 13, 2012, 15:28
I uninstalled then reinstalled ANSYS and now it works.
There are a few known issues when installing ANSYS on Windows 7. The problem seemed to be that ANSYS was installed in C:\Users\username instead of Program Files.
To avoid this problem, you have to turn off User Account Control and IPv6 before installing ANSYS.
Thanks again Ali for your help
Jérémie
Old   August 20, 2013, 03:10
apex is on a distinguished road
hi all
having a problem to import geometry from catia v5 to ansys 13.0 even whn i saved file in stp whn i import it to ansys it keep on saying Tetin file part1.tin does not exist current coordinate system global
help plz
Thanks
apex
apex is offline   Reply With Quote
Old   August 20, 2013, 09:08
diamondx's Avatar
Ghazlani M. Ali
i guess you are using icem cfd ? import the geometry using workbench reader... of course the tin file does not exist because you don't have one, this happens when you click on import geometry . try STEP/IGES/parasolid.
Regards,
Ali
Old   August 21, 2013, 05:16
Paritosh Vasava
vasava will become famous soon enough
It could be simply because you do not have a valid 'Design modeler' license. The 'can not attach....' error is common when you are missing valid Ansys modules or module licenses.
vasava is offline   Reply With Quote
Old   August 21, 2013, 08:41
Default failure to attach
  #15
thanks for the link very helpful... actually it still doesnt work... showing this time ...ERROR: pIPartMgr->AttachAssembly() failed!...... bt whn i open previous step file it does open bt when i open new one it show me tetin file doesnt exist...
help plz..
thanks
apex
Old   August 21, 2013, 10:37
diamondx's Avatar
Ghazlani M. Ali
ok have you tried importing it in designmodeler ?
Regards,
Ali
Old   August 22, 2013, 01:27
Paritosh Vasava
If its possible for you please share the other versions of your model (stp, iges..). We can have a look.
Old   January 25, 2014, 13:45
Huseyin Caner
Hcaner is on a distinguished road
I ve tried your steps.
I got this error
Hcaner is offline   Reply With Quote
Old   March 15, 2014, 09:34
Arjun KS
arjunks1000 is on a distinguished road
Please right click and run ANSYS CAD Configurtion Manager as administrator
arjunks1000 is offline   Reply With Quote
Old   March 18, 2014, 00:10
Johnson Jose
JAISE15 is on a distinguished road
I tried this but still this error is there..
I made a simple cube in design moduler and saved it.
when taking mesh it starts and goes away automatically
and then a x mark in mesh.
I tried cad configuration and also even reinstalled ansys still the issue is there...
JAISE15 is offline   Reply With Quote
error, workbench
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
Workbench geometry in to ICEM KM CFX 2 December 21, 2007 13:45
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
workbench geometry in ICEM Ross CFX 6 November 2, 2006 06:51
Virtual/Real geometry. Jack Keays FLUENT 9 June 15, 2000 23:39
