November 10, 2017, 08:01 |
Vertices number of an element
Javi
Rep Power: 16 |
I would like to know whether is possible or not to know the vertices of a particular element in your mesh. I have seen different TUI commands but only for blocking vertex and point locations but not for vertices number. Is there any way to get it? Do I need to look into the mesh file? Thank you in advance for your help! |
November 16, 2017, 12:41 |
Rep Power: 24 |
This should be possible. There are different options available under the info tab. You can try node info or element info. Furthermore you can activate some mesh information by doing a right click on mesh in display tree.
November 16, 2017, 14:11 |
Javi
Rep Power: 16 |
Hi Kad,
Firstly, thank you for your answer. To be honest, I think I solved the problem creating a subset by number of element and then activating the node numbers by right click on mesh tab. Thank you again for your answer |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
ERROR #001100279 has occurred in subroutine ErrAction. | smnaryal | CFX | 11 | December 20, 2017 16:32 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Two way Fsi Problem- Non linear problem | kmgraju | CFX | 4 | April 28, 2015 11:15 |
