November 22, 2017, 19:41 |
ANSYS import geometry problem
Ray
Rep Power: 12 |
Hi, I have a question regarding the geometry import into ANSYS workbench. When I export an assembly (sheet metal assembly by the way) from Solidworks into IGES, and then import it into workbench, I found there are hundreds of surfaces being generated. But if I export each part of the assembly from Solidworks into IGES, and then import each of them separately into workbench, everything works fine. there is only one solid for each part. So why is that? Anyone can help?
November 23, 2017, 05:17 |
Gwenael H.
Rep Power: 20 |
Hi Ray,
When you import your IGES, you should review your default import options in Design Modeler under the imported part in the tree outline > Stitch Surfaces > Yes Have fun |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
Import Mesh Problem: New to Ansys | EphemeralMemory | ANSYS Meshing & Geometry | 6 | July 24, 2015 05:28 |
NACA 0012 geometry import in ansys design modler | hardik47 | FLUENT | 4 | March 10, 2015 16:40 |
Ansys 14.5 Problem Import Mesh from ICEM CFD to CFX | Smiling Assassin | CFX | 1 | May 9, 2014 02:27 |
[Workbench] Import geometry problem | olique | ANSYS Meshing & Geometry | 0 | March 29, 2014 13:34 |
