[Workbench] meshing shows error
Old   November 25, 2017, 10:01
Default meshing shows error
Siju simon
sijusimon is on a distinguished road
While meshing my model in ansys workbench, the following error shows;
Error 1;
The source mesh cannot be correctly copied to the target surface. This might be because the surface is closed surface with degenerate​ points'.
sijusimon is offline   Reply With Quote
Old   November 26, 2017, 15:47
Gweher's Avatar
Gwenael H.
Gweher is on a distinguished road
Hi Simon,
What kind of setup / method are you using ? As suggested this may be due to a problematic area in your geometry or if you're using periodic BC and issues arise between source and target face. Also did you create or import the geometry ?
Gweher is offline   Reply With Quote
Old   November 26, 2017, 22:21
Siju simon
I created the model using ansys itself
Old   November 27, 2017, 08:41
Gweher's Avatar
Gwenael H.
Difficult to say without additional inputs from your side, don't forget a picture speaks a thousand words
Old   November 27, 2017, 13:36
Siju simon
Sorry...
My model was a reinforced concrete structure. I created​ the model using workbench and assigned all material properties. I thought it will automatically detect the bonding between steel and concrete. But it doesn't work. Didn't get the results and and error displayed. How can I give the interference between 2 materials​ in a single geometry. By using "manual contacts" option I tried but it doesn't work. I am very much new to Ansys software..
Old   November 27, 2017, 14:11
Gweher's Avatar
Gwenael H.
Well in your case you should put the parts (concrete // rebar) into a single multibody part so you'll have conforming mesh at the interface with no need to explicitly create a contact.
To do so in DM, select the bodies > rmb > form part. In SC you need to move them to the same component and under the property tab > share topology > group. You can refer to the help manual for additional details.
Have fun
Old   November 28, 2017, 23:19
Siju simon
As you mentioned earlier, I made a reinforced concrete beam and it really worked (sharing topology). But my problem is to model a RC beam- column joint. So there comes beam, column, beam rebar, column rebar, beam stirrup and column stirrup (attaching model-fig 1). Without any grouping, ansys automatically shows the contact region between rebars and stirrups. But not showing the contact between concrete and steel. Then I made all the bodies of my geometry to a single part and shared the topology. But it gave errors at the meshing stage of modeling (attaching fig 2). So again, I made all the bodies into 2 groups; bodies of column and bodies of beam. Then I shared the topology. Here comes another problem is that the beam rebars are going into the column. So, there should be a contact region between beam rebar and column concrete. Again, it shows errors at the meshing stage(attaching fig 3). Type of meshing I provided “coarse”.
Sorry for not providing details about the model previously…
Old   November 29, 2017, 08:27
Gweher's Avatar
Gwenael H.
Hi Simon,
Well I'm not surprised that your volume mesh failed as you have a really fast transition and dealing with different element sizes. You should definitively play with the meshing options like :
  • Relevance
  • Size functions (adaptive / proximity / curvature etc...)
  • Relevance center
  • Transition
  • Span angle center
You can also add inflation layers around your rebar and take advantage of local refinements. Moreover when you deal with contacts you can use either mesh connection groups (rmb on mesh > insert > mesh connection group) or contact match group (rmb on mesh > insert > contact match group). Depending on the contact algorithm you use the accuracy strongly depends on interaction between the components so you should definitively put effort in deriving a proper mesh.
Have fun
Old   November 29, 2017, 08:35
Siju simon
What about sharing topology..? Can I make all the bodies to a single group..?
Old   November 29, 2017, 08:41
Gweher's Avatar
Gwenael H.
Yes you can definitively do that too but you still need to play around with the meshing parameters to have a good end result
Old   November 29, 2017, 08:47
Siju simon
Thanks a lot
And Hoping your advice​s in future also..
Old   November 29, 2017, 09:24
Gweher's Avatar
Gwenael H.
Ansys also has a special finite element (Solid65) to model reinforced concrete with/without rebar. This can also be a nice alternative instead of explicitly modelling your rebar. Additional details can be found her
Ansys Solid 65 - 3D Reinforced concrete solid
Have fun
Old   December 9, 2017, 22:06
Siju simon
hi Gweher,
i have to cut certain portion of my model, a small portion of concrete and rebar from the bottom of beam. i have to add a new material to that portion. is it possible in ansys. what i supossed to do..?
Old   December 15, 2017, 14:16
Gweher's Avatar
Gwenael H.
Yes you can simply apply a different material to the parts in Mechanical if you have separated bodies (split them before in DM for instance).
Thread Tools
Trackbacks are On
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
