[Workbench] error in meshing
Old   November 25, 2017, 04:13
Default error in meshing
Siju simon
sijusimon is on a distinguished road
I Made a model of reinforced concrete beam column joint in ansys workbench. while solving the model, after giving all force and boundary condition, it shows following two errors:
error 1:
"The value of UZ at node 5073 is 6057083.95. It is greater than the
current limit of 1000000"
error 2:
"If one or more parts of the model are held together only by contact
verify that the contact surfaces are closed. Also make sure that
there are constraints (or friction) in the sliding direction even if
no load is applied in that direction"
how can i rectify these errors
sijusimon is offline   Reply With Quote
Old   November 26, 2017, 14:53
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Simon,
The errors are clearly stated and suggestions are even provided... Obviously your model isn't properly defined. Try to address the issue by constraining the model. Moreover you can highlight the problematic nodes by selecting the mesh id.
Gweher is offline   Reply With Quote
Old   November 26, 2017, 21:25
Siju simon
Thank you.
[ANSYS Meshing] Can start ANSYS meshing only one time on ubuntu 16.04 Touré ANSYS Meshing & Geometry 2 September 26, 2017 05:41
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 05:09
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
