[ICEM] Meshing of a pipe with a helix structure help needed
Old   November 30, 2017, 08:10
Default Meshing of a pipe with a helix structure help needed
Thijs
thijs1909 is on a distinguished road
Hello people,
For my master thesis I study fully-developed flows in pipes with a helix structure. The CFD analysis will be done in openFoam and the meshing the geometry using ICEM CFD 18.2 . The flow-domain (geometry) is first drawn using Solidwork and import in ICEM CFD using import model function.
My first thought was that I have to create a structured grid using hexahedral elements. So I used in ICEM the create block utility and associated edges to curves at both inlet and outlet. The following step I did was using ogrid and then pre-mesh. This is bassically the way to go for creating a structured grid for a pipe, but my mesh fails in accurately capturing the helix geometry.
My question is: is a structured hexahedral mesh possible? Or should I use something else. Or should I consider using an unstructured mesh?
Kind regards,
Thijs
thijs1909 is online now   Reply With Quote
Old   November 30, 2017, 13:29
kad
kad will become famous soon enoughkad will become famous soon enough
Your blocking does not respect the geometry of the helix at all. This why you get bad elements there. You have to account for the helix geometry by doing further splits associations and so on. I guess it would be rather painful to do a full 3D blocking for the whole geometry.
My idea is to try this one with the extrusion tool. So you begin with 2D blocking or mesh a e.g. the inlet and afterwards extrude with combined rotation and translation, which is possible in ICEM. Your extrusion parameters then have to fit your geometric parameters of the helix.
I took two quick shots at it, see attachments. First one is to start with a real easy blocking for the upper surface. After converting to unstructured mesh, the mesh is smoothed with orthogonality tool to improve the mesh in the small "bump region". Another strategy would be to improve the blocking itself. This is followed directly by the extrusion.
The second try starts with a unstructured quad dominant mesh. You can use the "curve mesh setup" parameters to create some kind of boundary layers. The rest is exactly the same procedure.
kad is offline   Reply With Quote
Old   November 30, 2017, 17:27
Thijs
Hi Kad,
Thank you for you tips and your effort for spending some time figuring out my problem. I will try this the first thing in the morning and I will report back with my experience.
Kind regards,
Thijs
Thread Tools
Trackbacks are On
Help needed for volume meshing issues sidharth9426 ANSA 3 March 6, 2016 13:40
[gmsh] Vertex numbering is dense KateEisenhower Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 August 3, 2015 10:49
separated pipe meshing tomokus OpenFOAM Meshing & Mesh Conversion 0 May 5, 2014 08:38
[ICEM] ICEM PIPE bend meshing firavia ANSYS Meshing & Geometry 3 December 23, 2012 10:29
Help needed to generate a graded pipe mesh. jenright OpenFOAM Native Meshers: blockMesh 0 August 22, 2009 08:58
