[BladeModeler] Simulation of several blade passages instead of full geometry
Old   December 7, 2017, 12:49
Post Simulation of several blade passages instead of full geometry
x125012
yahya_azizi is on a distinguished road
I'm performing a 3D CFD simulation of a stage of an axial flow compressor in order to assess a type of casing treatment to delay rotating stall. The Number of blades are as follows:
IGV 34
Rotor 36
Stator 35
Due to limited computational resource, the analysis of three passages instead of the full geometry is desired. The number of passages have been chosen based on spike stall cell extension in tangential direction. The IGV, Rotor and Stator blades have been defined in bladegen.
Does Blade Editor have the feature to consider several passages instead of full geometry? Should a cut or revolve functions be used in blade modeler to produce several passages or a CAD software should be used to make a cut through the full geometry?
yahya_azizi is offline   Reply With Quote
Thread Tools
Trackbacks are On
Automation of new geometry simulation Mustapha Khalifa Main CFD Forum 2 May 16, 2017 04:32
High loss coefficients in blade flow simulation pisykl FLUENT 1 May 30, 2016 21:27
Memory issues in full annulus simulation evan247 CFX 5 March 16, 2016 11:40
explaning about Passages per Mesh, Passages to Model and passages in 360 aja1345 CFX 0 October 16, 2015 10:02
Rotor 67 full compressor geometry jf Main CFD Forum 1 May 26, 2015 10:48
