[ICEM] Advancing Front fails
Old   January 2, 2018, 08:31
Default Advancing Front fails
Fabian Schicker
fabian.schicker is on a distinguished road
I'm currently playing around with the different options to generate meshes in ICEM, however I still fail to use the Advancing Front algorithm, even for trivial geometries. The mesh generation always fails with an error.
The workflow I used to test it with a simple geometry (https://pastebin.com/hLDT8V47):
1) Create 1x1x1 cube by adding points and creating surfaces
2) Set Part Max Size to 0.1
3) Add Material Point
4) Build Topology
5) Generate All-Tri surface mesh
6) Start Advancing Front meshing
The meshing fails with
Application did not finish correctly.
Error: afmesh exited with a non-zero status
No afmesh mesh generated!
I see no other error messages in the log before that. I uploaded the complete log (with verbose output) to pastebin: https://pastebin.com/zE56p1zG
The result is the same when I generate the surface mesh by doing an Octree meshing and deleting the volume elements.
Does anyone know how to setup the AF-mesher correctly?
fabian.schicker is offline   Reply With Quote
Old   May 22, 2020, 22:56
Mostafa
bikooo3878 is on a distinguished road
facing the same issue any solution?
bikooo3878 is offline   Reply With Quote
Old   May 24, 2020, 20:35
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
try delaunay then to AF
shereez234 is offline   Reply With Quote
[ICEM] ICEM-CFD, Advancing front kdgha ANSYS Meshing & Geometry 2 September 21, 2020 13:55
Icem Tetra- smooth advancing front sonic109 Main CFD Forum 0 March 29, 2015 11:51
Octree Vs Advancing Front tetra meshing techniques Sam CFX 4 February 18, 2008 09:54
Advancing Front Techniques Dinesh Godavarty Main CFD Forum 7 October 30, 2000 00:27
Front tracking Don Hawken Main CFD Forum 1 December 12, 1999 14:29
