[DesignModeler] Convertinga 3D geometry to 2D |
February 11, 2018, 10:04 |
Rep Power: 14 |
Hi All
I am trying to convert a complex 3D water turbine geometry to 2D to start a 2D simulation to see the cross flow effects. But I am not able to generate the 2d surface or the geometry from Ansys. I tried to create a new plane and use the sketch projection and then I get the 2d cross section but its in construction lines which means there is no lines and hence I am not able to save it as a 2d geometry. So I am not sure which is the other best method for this. Kindly help me on this. Cheers !! |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 02:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 13:02 |
How to scale and translate the grid of particle data and STL geometry | Saidul | Tecplot | 1 | January 11, 2015 21:15 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
