[ANSYS Meshing] Difficult meshing/interfaces. |
February 21, 2018, 07:46 |
Henry
Rep Power: 8 |
Problem,
I am modelling a galvanization furnace. The fluid domain is covered by insulation and heats a kettle. There are 8 inlets (4 for air) (4 for methane). I want the mesh really fine around on the inlet and it's surrounding areas. Would having an non conforming mesh then using mesh interfaces in fluent be less accurate than having conformal meshes between the solid parts and the fluid domain when modelling heat transfer Best wishes Henry |
Which are the aspects you consider most difficult to learn of OpenFOAM to new users? | albertokarkour | OpenFOAM | 5 | October 18, 2016 02:50 |
How difficult is it to model a parrafin wax phase change? | jmckenzie | OpenFOAM | 3 | August 29, 2016 02:37 |
Difficult to understand؟ | hamidciv | CFX | 1 | April 6, 2013 05:12 |
why it is difficult to get converge in dissipation | frank | FLUENT | 0 | January 9, 2006 05:24 |
cfx is Difficult to learn? | SAM | CFX | 3 | October 31, 2004 17:05 |
