[ANSYS Meshing] Transition between two hex sections with different cell density
Old   February 22, 2018, 03:15
Default Transition between two hex sections with different cell density
krihamm is on a distinguished road
I am running high speed simulations over a large body in order to obtain aerodynamic parameters. Since the speeds are very high (several Mach numbers) and the body is large, I need a large fluid domain so to capture all aerodynamic effects. The mesh section around the body is very fine, but in order to save meshing and computational time I want the cell density to decrease further away from the body. The mesh around the body is tetra, but surrounding sections are hex.
I first tried meshing the different hex sections with just different body sizes. This, however, resulted in highly skewed elements. I then added a section of tetra mesh between each hex section for smoother transitions (see attached file). This looks fine to me, but I was wondering if adding such sections could affect the simulations in any negative way in terms of accuracy. Is there any other way to obtain what I want?
Thanks!
krihamm is offline   Reply With Quote
ill defined primitive entry 'boundary' francisco.angel OpenFOAM Pre-Processing 16 September 8, 2022 06:11
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 04:27
strange problem with data seav OpenFOAM Running, Solving & CFD 0 April 11, 2014 05:01
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 12:25
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
