[ICEM] Trimming a a surface using a circle causing error |
March 22, 2018, 04:40 |
Rohit
Rep Power: 9 |
Hello dear friends,
I am creating a section of a cylinder sector containing a liner with radial holes. The steps I followed: I created a cylinder through the cylinder curved surface (first image) Then I created an intersection curve using these two surfaces (third image). I used trim/segment surfaces to segment the curved surface using the curve made earlier. (fourth image) But when I delete the segmented curve, I get a rectangle hole (fifth image) and not a circular hole. How do I fix this and get a circle hole? 1.jpg 2.jpg 3.jpg 4.jpg 5.jpg |
March 22, 2018, 07:09 |
Gert-Jan
Rep Power: 27 |
Probably this is just a visualisation issue.
If you go the tree of Geometry and right click on Surfaces and select Show Full, then you'll see it is a circular opening. |
March 23, 2018, 01:12 |
Rohit
Rep Power: 9 |
Display Modes | |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
