April 3, 2018, 11:30 |
Meshing Mandible Implant
Sander Put
Hi all,
I've been trying to mesh a certain part for the past couple of days. The part is made up of 3 solids. The first is the outer jawbone, the second is the inner jawbone and the third is the plate that holds everything together. If I try to mesh these geometries (Patch Independent) it gives me the error: "The number of unconnected mesh volumes differs from the number of bodies is that part." I've done this type of analysis before, but not with the two different bone parts inside one another. I would appreciate all the help I can get! |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
