April 23, 2018, 06:11 |
Torus in spaceclaim
I need some help how to create shell torus in spaceclaim with 0 thickness
help in advance regards |
April 23, 2018, 06:18 |
Bond Chris
Rep Power: 8 |
I believe it is not possible to create a single closed surface in SpaceClaim, as it would get automatically converted into a solid. You could make a small hole in the surface so it is not completely closed.
April 23, 2018, 06:20 |
tnx for quick reply
i hope a good old designmodeler will help me regards |
April 23, 2018, 08:36 |
Paritosh Vasava
Rep Power: 22 |
Could you try these two options and see if any of it works:
April 24, 2018, 04:38 |
Nope
according to my experience and by using of your hint is not possible to achieve 0 thickness regards |
April 24, 2018, 04:45 |
Gert-Jan
Rep Power: 27 |
It works if you can live with a torus that consists of 2 surfaces.
1) create a torus 2) split it in half 3) right click on one of the surfaces and select detach Then you end up with 2 surface bodies (of zero thickness) that span up 1 torus. Isn't that suitable? |
April 24, 2018, 04:50 |
I did it by pulling two arcs around the same axis then share topology.....
it is not the best solution but it worked |
April 24, 2018, 04:53 |
For structural analysis it is not suitable
April 24, 2018, 05:04 |
#9 |
Gert-Jan
Rep Power: 27 |
ICEM works with points lines and surfaces. So, if you import a Spaceclaim solid of a torus into ICEM, you end up with a single surface. Then you can export it as a stl or iges file.
Haven't tried it but you can........ |
April 24, 2018, 05:06 |
#10 |
designmodeler solved the problem
[Other] Import airfoil SpaceClaim | myaero | ANSYS Meshing & Geometry | 4 | May 16, 2020 08:52 |
Importing geometry from spaceclaim to icem cfd | Sumanth Bhat | Mesh Generation & Pre-Processing | 1 | April 12, 2018 10:55 |
How well does Spaceclaim integrate with ANSA | laminarflow027 | Main CFD Forum | 0 | August 18, 2014 10:09 |
Meshing Torus | prikeyma | ANSYS Meshing & Geometry | 0 | August 2, 2011 16:03 |
Oddity in meshing half a torus | Maarten | FLUENT | 0 | March 12, 2004 08:04 |
