Design Modeler scripting
Hi all,
I need to automatically create a set of spheres, depending on a list of point coming from an external file. I tried using a .js macro and until now I produce the following: Code:
//Import the points
Can please someone help me or tell me where can I find a list of example and tutorials? Thank you Lorenzo |
Solved
Sorry, I just solved it:
Hi Lorenzo,
I'm dealing with the same problem, gotta generate a plate with random holes in it and mesh it, all automaticaly using script, would you mind sharing your text file containing the points you used in your script? I wanna generate the points using a code, but not sure yet how I should arrange them inside the text file |
Hi, you can refer to this topic for the format!
https://www.cfd-online.com/Forums/an...n-modeler.html |
got it, thanks |
