June 11, 2018, 07:30 |
Negative Cells in Sharp Corner
Daniel
Rep Power: 9 |
I have a problem with negative cells. The Blocking is shown in the Pictures. There is a sharp edge in my blocking where, when i plot the determinante 2x2x2, negative cells appear. However i minimze the cells the negative cells are still there. And I can't put a y-block into this triangle (error: Number of degenerate corners != 2) Is there any other option for this problem ? Thank you ! |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Negative volume cells | nbons | STAR-CCM+ | 2 | January 27, 2015 12:18 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
