July 3, 2018, 03:16 |
ERROR:cannot form boundary layers
dy
Rep Power: 8 |
Dear all
There is a problem that makes me confused. I'm trying to mesh a IGV passage domain. However, when i apply boundary layer mesh to shroud face, a message"ERROR:cannot form boundary layers on edge edge.ID of face face.ID without intersection." appears and the boundary layer mesh is failed. So, my question is 1.what does this message mean or What problem occurs in my geometry model? 2.What should i do to solve this problem? Thanks a lot. ddyy |
July 3, 2018, 04:47 |
Maxime Perelli
Rep Power: 41 |
can you post some pictures of your issue?
In memory of my friend Hervé: CFD engineer & freerider |
July 3, 2018, 07:26 |
dy
Rep Power: 8 |
Thanks for your reply, max. When i open the .dbs and plan to capture some pictures, i find that the boundary layer backgroud mesh (white lines in pictures) is generated successfully. But it was failed when i submited my thread to forum.
July 3, 2018, 07:30 |
dy
Rep Power: 8 |
Dear max
Well, there is another problem when i continue mesh. The mesh in a face is failed. |
July 3, 2018, 08:02 |
Maxime Perelli
Rep Power: 41 |
did you pick also the top and bottom faces of your domain?
if yes deselect them, you only need to select the solid surfaces (wall) of your foil
July 3, 2018, 08:29 |
dy
Rep Power: 8 |
I didn't select the hub and shroud surfaces. The blade surface consists of six surfaces. The blade surface mesh is failed in one of the six surfaces. In other five surfaces, the surface mesh is generated successfully. I wanna know what may cause the "ERROR: The boundary layers associated with face ID are conflicting and/or will overlap".
July 3, 2018, 09:04 |
Maxime Perelli
Rep Power: 41 |
can you upload your dbs file somewhere?
July 3, 2018, 09:42 |
dy
Rep Power: 8 |
Sure. I will upload my dbs file tomorrow.Thank you max.
July 3, 2018, 21:54 |
#9 |
dy
Rep Power: 8 |
My dbs file is too large to upload.
July 4, 2018, 00:52 |
#10 |
Maxime Perelli
Rep Power: 41 |
upload it on a share server like dropbox or whatever
July 7, 2018, 04:45 |
#11 |
dy
Rep Power: 8 |
Dear max
I'm Sorry for not replying you in time. Because i spent some time to compress my dbs file under limit. Here is zip file. |
July 9, 2018, 00:52 |
#12 |
Maxime Perelli
Rep Power: 41 |
Ok
Now you have to give me the detail of your mesh, In this way I ill be able to recreate same configuration as yours
July 11, 2018, 09:03 |
#13 |
dy
Rep Power: 8 |
I want to create boundary mesh at shroud, hub and blade surfaces. When blade surface boundary mesh is going to be created, i get in trouble. The specific mesh parameters are displayed in figure 1,2,3.
July 12, 2018, 01:04 |
#14 |
Maxime Perelli
Rep Power: 41 |
enable "internal continuity" option
July 12, 2018, 01:33 |
#15 |
dy
Rep Power: 8 |
Yes, it works. Thank you very much for helping me solve this confusing problem, max.
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
