[DesignModeler] problem with geometry construction |
asdf;lkj
Rep Power: 4 ![]() |
i have a vertical and horizontal perpendicular plate connected with bolt,
1) at interface (contact surfaces)created surface by create from faces, (this surface helps to give resistance and conductance value) 2)when i made all parts to be a 1 part 3 bodies in DM, i can't see the surfaces created at interface in mesh tool, 5)if i make 1 part 3 bodies and topology is imprint, giving the surfaces and bodies error. 6)when i do 3 parts 3 bodies and shared topology operation i could see them in mesh tool and we performed mesh operation, and named all the walls and after i enter into the fluent i could't see the 1 surfaces which we need to control this surfaces in BC. simple geometry trying to simulate heat transfer b/w bolted plate Last edited by vijaybr1993; July 26, 2018 at 08:54. |
Display Modes | |
[ANSYS Meshing] Problem in geometry meshing | Itachi11 | ANSYS Meshing & Geometry | 3 | March 15, 2016 14:38 |
Autodesk Inventor geometry problem | Whitebear | CFX | 3 | November 24, 2015 18:24 |
Problem with Scale in Geometry | bejanyar | CFX | 4 | October 14, 2015 07:53 |
[ANSYS Meshing] Problem with geometry | paul115 | ANSYS Meshing & Geometry | 4 | August 18, 2015 12:18 |
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? | Pol.P | FLUENT | 8 | May 28, 2015 05:54 |
