[ANSYS Meshing] reducing airfoil points while keep the overall shape smooth |
April 29, 2023, 19:11 |
Kessali
Rep Power: 3 |
Hello Fellow CFD users , I'm currently facing a problem , after optimizing my airfoil shape and extracting 2D coordinate points , i want to make an analysis using xflr5, but i have more than 300 points , how can i manage to lower the number of dat apoints while keeping the airfoil shape smooth and fit the original
thanks in advance |
May 2, 2023, 07:42 |
Daniel
Rep Power: 9 |
What is the limit?
I would try to load my data into python (or MatLab or a CAD tool, whatever you prefer) and delete points in a regular pattern, for example every 3rd or 5th point will be deleted, until you reach the software limit. Then plot your datas against each other. I assume that the overall shape will be well represented (in an acceptable range) although using fewer points. |
Display Modes | |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 13:16 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[Other] Mesh refinement and smooth interface shape | Prosper | OpenFOAM Meshing & Mesh Conversion | 2 | May 5, 2015 16:21 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
