Scripting named selections for use in downstream applications (ICEM and CFX)
Hi everyone,
I have a centrifugal pump fluid domain CAD geometry which I have created in FreeCAD (and so it is a STEP or IGES file). Unfortunately FreeCAD does not support the use of named surfaces, and so I need to use another application to name these faces for downstream applications. From what I've read, https://www.cfd-online.com/Forums/an...ry-import.html, this is not possible using workbench journalling. Therefore I would like to create a script for use in DesignModeler to take in this geometry and create named face selections using some pretty easy criteria (i.e. area and/or a point on the surface). This is will need to performed from command line. I've only managed to create a js file to import the geometry, which I can run from batch. Code:
// start from clear scratch Kind regards, James |
