[ANSYS Meshing] How Fluent calculates layers in First layer thickness |
August 10, 2018, 09:02 |
South Yorkshire
Rep Power: 7 |
I am performing a boundary layer mesh around a circumference. I selected the Inflation option with the following parameters: Method: First layer thickness. First layer size: 0.01 mm Max. number of layers: 40 Growth rate: 1.2 I realised that, depending on the number of elements that the circumference is divided, that extent of the inflation layer changes. For example, if I divided my circumference into 60 or 120 elements, the inflation layers extent radially 43 mm and 19 mm respectively. Maybe it has something to do with the aspect ratio of the first layers. Anyone knows how fluent calculates the layers in this methods? Thanks, |
fluent, inflation layer, meshing |
Total Thickness of Inflation Layer | prikeyma | CFX | 5 | August 28, 2020 03:22 |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
[snappyHexMesh] proble of creating layers with snappyHexMesh | comingdaytime | OpenFOAM Meshing & Mesh Conversion | 3 | May 24, 2018 06:18 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
