[DesignModeler] Need some help for Modeling for CFD Analysis |
August 9, 2018, 04:56 |
Saha
Rep Power: 7 |
I'm using Ansys Fluent..
The two pipes in attached geometry figure are intersecting. I want the fluid flow in the main (larger) pipe, to get obstructed by the smaller pipe where it is protruding into it. The flow from smaller pipe should mix with the main fluid flow from the sides and bottom of larger pipe. I tried running a simulation, and not getting the desired contour/vectors. Basically, mixing is not proper, and I suspect it's due to the geometry. Below are images for what I need: https://ibb.co/b5rXo9 https://ibb.co/ndMnMU PS: I tried Boolean, but I think I did something wrong in its application. Really looking for some guidance here for the geometry! Thank You! |
August 11, 2018, 03:25 |
#2 | |
Rep Power: 8 |
I think the problem here might be that you have to apply some wall thickness to the small part of pipe inside the large pipe. |
August 12, 2018, 04:02 |
Saha
Rep Power: 7 |
ansys, cfd, design modeler, fluent, geometry |
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation | JPBLourenco | SU2 | 1 | April 23, 2018 10:38 |
Explicit dynamics results for initial condition to another explicit dynamics analysis | KOI | Structural Mechanics | 0 | March 2, 2018 04:16 |
How to implement a sensitivity analysis for certain items | Mason liu | CFX | 10 | August 17, 2017 08:46 |
Flutter analysis of compressor blade | sridharabc228 | CFX | 1 | April 13, 2017 19:10 |
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 14:04 |
