[GAMBIT] How to split a hollow sphere in different angles |
August 15, 2018, 20:25 |
Aja
Rep Power: 14 |
I want to split a hollow sphere with narrow thickness in different angles with respect to meridian. How can I do it in Gambit? I don't want to split this hollow sphere in specified point in form of inclined. I wan to split it as follows (is created smooth surfaces): I am grateful that guide me in this case. Thanks. Last edited by aja1345; August 19, 2018 at 09:22. |
August 16, 2018, 08:38 |
Maxime Perelli
Rep Power: 41 |
Check my picture:
Capture.JPG I would create a point outside your sphere on the (Oy) axis (point A) Then create a copy of this point A via rotation of desired angle around (Oz)-axis (point B) From point B create its symmetric in respect of Plane (YZ) (point C) BC lies on Plance (XY) Expand point B and C along Z>0 axis (Points D and E) Same along Z<0 (Points F G) Now you are able to create Surface (DEFG) Split your sphere with this surface That's it They are other ways, but with this one you use the angles
In memory of my friend Hervé: CFD engineer & freerider |
August 16, 2018, 11:53 |
#3 | |
Aja
Rep Power: 14 |
This is many useful. Thanks a lot max |
Display Modes | |
[Other] 2D adaptive Mesh Refinement | baco | OpenFOAM Community Contributions | 80 | August 14, 2022 15:18 |
[snappyHexMesh] Sphere in a channel by snappyHexMesh | arsalan.dryi | OpenFOAM Meshing & Mesh Conversion | 0 | November 14, 2016 17:01 |
Hollow sphere | iside | ANSYS Meshing & Geometry | 2 | July 26, 2011 11:19 |
How to split a sphere in ICEM? | zhaohui | ANSYS Meshing & Geometry | 3 | March 31, 2010 11:36 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
