September 12, 2018, 13:43 |
How to mesh sharp corners in ICEM CFD
Abhi
Rep Power: 8 |
I`m trying to mesh the geometry attached using quad-hex cells. I`m facing problem at sharp corners and hence mesh is showing a quality of 0.01. Please give a look and suggest how to improve quality in this.
September 13, 2018, 05:29 |
Gert-Jan
Rep Power: 27 |
What do I see in the picture? I see geometry lines, and blocking lines? What is which?
September 18, 2018, 03:41 |
Abhi
Rep Power: 8 |
Dear Gert-Jan,
I`m attaching .Zip file with all details. I`m unable to get good quality mesh using quad-hex cells. Can you help me with this. |
September 18, 2018, 05:27 |
Sebastian Engel
Rep Power: 20 |
Hi Abhi,
have a look into the sticky post of this subforum (again). There you'll find an awesome guide called: Simon’s tips and trick on ICEM CFD On slide 97 and 98 you'll find a similar problem solved with different methods. The problem is, plain hexa is not suited for such corners. Try to understand why the quality criterion returns 0.01? Also check against skewness, and determinant, try to understand what these quantities mean. By then, you'll understand why a rectangle squeezed to almost a line will result in bad quality criterion. Best regards, Sebastian |
September 20, 2018, 01:30 |
Abhi
Rep Power: 8 |
Dear Sebastian,
I tried that option but quality is not going beyond 0.04. Best Regards, Abhi |
October 7, 2018, 08:08 |
Abhi
Rep Power: 8 |
Dear Sebastian,
Thanks for help. Got the quality to 0.22. Best Regards, |
How to create solid to fluid interface in Fluent using an ICEM CFD mesh. | ekraft | FLUENT | 1 | June 15, 2017 11:59 |
Import Mesh from ICEM CFD to CFX | Andre Almeida | CFX | 16 | April 19, 2016 03:42 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
ICEM CFD 5.0 - 2D to 3D Mesh Extrude | James Date | CFX | 7 | October 22, 2013 03:46 |
[ICEM] Problem with volume mesh in ICEM CFD | kolapoasafa | ANSYS Meshing & Geometry | 2 | September 16, 2011 03:54 |
