[GAMBIT] Sweep Problem
Old   September 14, 2018, 10:43
Default Sweep Problem
acalado's Avatar
André
acalado is on a distinguished road
Greetings,
I am having some issues with Gambit:
For some reason when I try doing a sweep of a face to create the volume, the rendered volume does not seem to match the edge lines (in green - see pic)
If you have any idea why this is happening I would appreciate your help.
Thanks!
Sapere aude!
acalado is offline   Reply With Quote
Old   September 17, 2018, 05:44
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
This is only a rendering
Mesh your volume and check if you still have this "distorsion" along the mesh.
If yes, I would suggest you to do some spit along the "extrusion"-edge
I remember I had such problem by "long" sweeps
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 17, 2018, 16:02
acalado's Avatar
André
Thanks for the reply.
I split up the volume in to smaller pieces and it apparently solved the issue.
Sapere aude!
Convergence Problem in Multiphase problem (three phases) m.uzair FLUENT 0 August 2, 2018 08:23
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
