[ANSYS Meshing] body of influence vs. contact region |
July 14, 2016, 16:52 |
Rep Power: 10 |
I'm using body of influence for the meshing from one region to another, but everytime I set up the element size/body of influence setting the contact region between those two regions changes into a question mark...
Does anyone know which problem could arise here? edit: maybe to clarify. As soon as I select the body of influence and hit select the contact regions of this body of influence become a question mark. |
July 17, 2016, 23:32 |
Rep Power: 13 |
put some pics
delete all auto generated contacts and create contacts manually |
July 18, 2016, 05:38 |
Rep Power: 10 |
Thx for ur reply. I sorted this problem...Sorry not to mention: The issue was that I didnt use multibody for my parts an thats why many contact regions arose. With multi-body in DM this issue does not arise. Though still now I have another problem instead. The body of influence chosen is not considered in the mesh. It's gone and I have a gap in my body :-/
U want some pics about it or is it clear enough? |
July 18, 2016, 19:36 |
Rep Power: 13 |
pics are equivalent of 1000 words.
SO always post pics and describe the problem. |
October 9, 2018, 10:17 |
#5 | |
yanki cob
Rep Power: 8 |
Did you solve this problem? Basically I want to use Body of Influence, but I also want to keep the "body". Is this even possible?
October 10, 2018, 08:41 |
Rep Power: 10 |
Unfortunately not :-(
I guess I "solved" it by splitting my body into a couple of parts and choosing different element sizes for each of them. But if you find a solution I'll be happy if you share it :-) |
Display Modes | |
[ANSYS Meshing] Body of Influence and Method on same geometry possible?! | pizzaspinate | ANSYS Meshing & Geometry | 0 | January 4, 2016 11:45 |
help with UDF for contact angle based on contact line velocity | gandesk | Fluent UDF and Scheme Programming | 14 | October 29, 2012 14:58 |
how to contact multi fluid region in ansys DM | oilsok | ANSYS Meshing & Geometry | 1 | January 14, 2011 18:06 |
Extracting fluid flow region from a solid body 3D | Pradeep | Main CFD Forum | 6 | January 29, 2009 12:13 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
