October 11, 2018, 03:41 |
The Mesh Problem in ICEM CFD
Kiko
Rep Power: 8 |
Hello
I need help with making my mesh smooth..i keep getting bad mesh...affecting my quality. I am doing mesh on the NACA 0012 blade..using ICEM CFD. |
October 24, 2018, 07:31 |
Gwenael H.
Rep Power: 20 |
Hi Kiko,
Looks like a bad edge to curve assignement. I would re-associate the edges once again and re-run the pre-mesh. |
October 24, 2018, 21:44 |
Kiko
Rep Power: 8 |
Thank you for the reply. I changed the geometry and all is good. I am just facing a new challenge with making the periodic. The vertices and periodic arrows seem to fail to associate. See the image.
If possible advise me step by step on how to resolve this. I will really appreciate. |
October 25, 2018, 15:23 |
Gwenael H.
Rep Power: 20 |
Hi Kiko,
Nice to hear that you've managed to solve the first association issue. Concerning the periodicity, what is the geometry you start with? What periodicity do you want to define ? If you go under the Mesh Tab > Global Mesh Setup > Set up Periodicity (last icon on the right) > then select if you want transnational or rotational periodicity. If you do it at a blocking level you need to go in the Blocking Tab > Edit Block > Periodic Vertices and select the periodic vertices pair and repeat the procedure with all the periodic vertices pair of your model. Hope this helped. |
October 26, 2018, 07:36 |
Kiko
Rep Power: 8 |
Hello Gweher,
Thank very much for the response. I am working on rotational simulation of the wind turbine blade. I am trying to get results for the thrust and the torque from the NACA 0012. The idea, for now, is to try it with 2D and 3D simulations. So, I was getting stuck when the vertices couldnt associate. Is it okay to set make periodic from fluent? I have added the rough ideal of my geometry. I had tried this using default mesh and I am trying to use structured mesh now in ICEM CFD. Regards, Kiko |
ICEM cfd 2d tetra mesh with Prism layer Problem | Bmalgil | ANSYS | 0 | March 4, 2018 14:26 |
How to create solid to fluid interface in Fluent using an ICEM CFD mesh. | ekraft | FLUENT | 1 | June 15, 2017 11:59 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 10:06 |
ICEM CFD Prism Mesh Generation Problem with Ansys 12.0 & windows 7 OS | kh_thakor | ANSYS Meshing & Geometry | 1 | February 1, 2011 20:22 |
