November 7, 2018, 07:47 |
Refine mesh with inflation
Andreia
Rep Power: 7 |
I'm very new at fluent and doing a 2D simulation of a valveless pulsejet, a did the mesh with inflation in order to obtain a yplus between 30 to 300 but now i'm trying to do a study of mesh independence but it is not converging. The refinament option is not available so i'm decreasing the element size but i'm not changing the inflation, should i refine the inflation too? But how? Please help me |
November 7, 2018, 09:53 |
Baris PULAT
Rep Power: 9 |
Hey Andreia,
- If your first yplus values are all in range, you shouldn't change the dimension of your first inflation layer in your mesh study. - But if necessary you can work around the total number of inflation layers. - To refine or to coarsen the mesh, playing with the element size is correct. - If the simulation is not converging with a coarser mesh this means you should refine the grid resolution and cross-check your results. Baris |
November 8, 2018, 05:17 |
Andreia
Rep Power: 7 |
Thank you, i will try to change the number of layers.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[ANSYS Meshing] Problem with Inflation Descreasing Mesh Quality | wildan | ANSYS Meshing & Geometry | 20 | March 4, 2019 03:29 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
