ICEM Meshing of Helical Finned Tube
Like Tree1Likes
  • 1 Post By ammarali311
Old   December 3, 2018, 12:32
Default ICEM Meshing of Helical Finned Tube
Ali
ammarali311 is on a distinguished road
Hello, I am working on a project for calculating pressure drop and heat transfer characteristics of internal helical finned tube. The dimensions of fins are very small as compared to the tube diameter. Hence they are called micro-finned tubes. I am having a difficulty in meshing the geometry in ICEM. The procedure that I am following is this
1) Import CAD model in ICEM.
2) Generate a 2D Surface Blocking of the inlet surface.
3) Meshing the 2D Surface Blocking using Pre Mesh Edge Parameters.
4) Extruding the 2D Blocking Mesh Surface along the helical curve of the fin to the outlet.
The problem is that I am not getting a good quality mesh using edge parameters. I need dense mesh at the fin boundaries and walls of the tube for accurate results and then from there the mesh density should decrease to the center of the tube because gradients are not very important at the center. But I am getting very dense mesh away from fins and walls which is making number of elements very large. Maybe I am not using efficient blocking for mesh distribution, I don't know. Can anyone help me in meshing this geometry. Thanksp1.PNG
UchihaMadara likes this.
ammarali311 is offline   Reply With Quote
[ICEM] ICEM Meshing troubles kdupont ANSYS Meshing & Geometry 1 June 23, 2017 04:00
[Commercial meshers] Icem cfd meshing badwalgurpreet OpenFOAM Meshing & Mesh Conversion 1 February 6, 2017 05:19
[ICEM] ICEM Meshing Problem-2D Unstructured Tariq Ahmed ANSYS Meshing & Geometry 0 August 25, 2016 16:13
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? pipolaki ANSYS 0 December 6, 2013 08:12
[Commercial meshers] Meshing open shell in ICEM Jenny_W OpenFOAM Meshing & Mesh Conversion 0 June 7, 2012 17:54
