[ICEM] Cooling Holes
Old   January 20, 2019, 03:10
Default Cooling Holes
serg
kont87 is on a distinguished road
Hi, I was wondering if i can mesh a stator vane with holes located over the surface, for example showerhead holes located near the leading edge or as in tip cooling holes over the tip floor in turbines.
I am new to ICEM, trying to learn it from videos on the internet and i did not find any turbomachinery tutorial with additional surfaces over the airfoil.
Any help is appreciated.
S.
kont87 is offline   Reply With Quote
Old   January 22, 2019, 17:34
Gert-Jan
Gert-Jan will become famous soon enough
Your question is something like:
'I have seen a car and want to build one. Who can tell me how?'
Don't expect answer from this kind of questions. You to be much more specific on the problems you encounter in ICEM......
Gert-Jan is offline   Reply With Quote
[ANSYS Meshing] Meshing a flat plate with cooling holes with a plenum using Centaur as a Meshing tool TheStudent ANSYS Meshing & Geometry 0 March 13, 2017 09:58
[ICEM] ribbed passage with cooling holes raorp ANSYS Meshing & Geometry 2 September 25, 2013 09:37
modeling cooling holes in turbine blades rajesh kumar gupta Main CFD Forum 1 September 9, 2010 12:13
Unbelievably high velocity magnitudes in film cooling - HELP! shankara.2 FLUENT 0 June 1, 2009 22:43
Passive cooling system for batch reactor Darek Main CFD Forum 0 September 30, 2003 05:06
