[ICEM] Imported wavy micro-channel shows too many holes in ICEM
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   March 8, 2019, 09:30
Default Imported wavy micro-channel shows too many holes in ICEM
Koustubh Bhagat
krb_1306 is on a distinguished road
Hey!
I am new to ICEM. I created a wavy micro-channel in Solidworks and imported it in ICEM. The issue is that the geometry appears to have no holes in solidworks but on importing on ICEM, a lot of holes are generated. Tried using the repair option in ICEM. It worsened the situation.
I tried merging surfaces to remove holes which caused issues while meshing.
What options do I have?
krb_1306 is offline   Reply With Quote
Old   March 8, 2019, 09:42
Gert-Jan
Gert-Jan will become famous soon enough
Probably your geometry is ok. ICEM is just simplifying your geometry to speed up graphics.
It you go to the tree on the left hand side and in Geometry select Surfaces with your RMB, then you can select "Show Full" and you'll find out your geoemtry is ok.
Regarding your hex mesh, difficult to say. What do we see? Is this the pre-mesh or the unstructured mesh? If Pre mesh, do we see 'Project Edges' or 'Project Surfaces' (look for these options using your RMB in the tree under Pre-Mesh)
krb_1306 likes this.
Gert-Jan is offline   Reply With Quote
micro channel heat exchanger design serpil kaya Main CFD Forum 6 March 25, 2018 08:34
[ICEM] Why do models imported into ICEM get distorted? dominique120 ANSYS Meshing & Geometry 0 March 16, 2017 17:46
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 05:06
Structured mesh in ICEM for rectangular channel Josh ANSYS Meshing & Geometry 5 March 12, 2010 15:53
micro channel arashmarahel180 FLUENT 4 January 20, 2010 11:56
