solid surface or wireframe, who do I trust?
Hi!
Context : Being a bit new to ICEM, I'm tasked with making watertight a plane geometry generated by ICEM from a CAD file. Needless to say, ICEM does the best it can but a lot of small connectivity problems arise. Problem : I don't know how to confirm if the geometry is watertight since the surfaces match in wireframe view but they don't in solid view. When I Create/Modify curve > extract curves from surfaces the curves also seem to be watertight, but I know the software may not create a surface that perfectly follows the curve if there is approximation problems. Example : https://photos.app.goo.gl/gD6Kyqs8MgVV2xXh6 Here, there is a hole between blue and dark black surfaces, but the wireframe and curves merge correctly, so who do I trust? https://photos.app.goo.gl/gD6Kyqs8MgVV2xXh6 https://photos.app.goo.gl/gD6Kyqs8MgVV2xXh6 |
