[Workbench] problem on dynamic mesh in sweep method |
April 13, 2019, 11:57 |
javid
Dears
is there any one to help me about how to set dynamic mesh adjustment for re meshing & smoothing method on sweep mesh? I'm working on FSI study for transient flow over vertical beam.I've used sweep mesh(all tri) in deforming zone and adjust dynamic mesh for smoothing(diffusion) & re meshing(local cell,local face,region face)but my problem is, when i get run,only smoothing method is working.regarding the point that,the deflection of beam is high,i will face with negative cell volume. the pics are in attached too. What's your helpful advice in this respect? waiting for your kind replay |
Sliding / Dynamic Mesh in heat transfer problem | platzhalter | FLUENT | 0 | May 7, 2018 05:25 |
6DOF Dynamic Mesh Problem with Overset Meshing - Weird velocity contour | Caster_Troy | FLUENT | 1 | December 7, 2017 06:19 |
Problem concerning FLUENT dynamic mesh | fabian.g | FLUENT | 0 | August 28, 2017 11:56 |
Dynamic Structured mesh around cylinder problem!!! | ludosbiz | Mesh Generation & Pre-Processing | 2 | March 23, 2016 15:15 |
Dynamic Mesh Problem | peatmac | FLUENT | 9 | March 14, 2012 06:11 |
