[ANSYS Meshing] Meshing a fin
Old   May 27, 2019, 06:51
Default Meshing a fin
egge24 is on a distinguished road
Dear all,
I'm trying to do a simple simulation of fin but I have got stuck doing the mesh. I'm getting errors all the time and I'm not sure why. The geometry of the fin is very fine, it is made of 83481 faces (see attached figure).
The errors and warnings I'm getting in Meshing are of the type:
  • A mesh could not be generated using the current meshing options and settings.
  • The specified defeaturing tolerance was found to be larger than a specified size. The elements on one or more edges may be defeatured out.
  • One or more surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology.
  • One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. However, meshing might be successful on the other entities.
  • Some boundaries of protected topologies have been defeatured. Right click on this message and select "Show Problematic Geometry" to see the affected edges.
I'm using a sizing for the fin with a size element of 0.1 mm (the fin is 100 mm length, 150 mm height and 5 mm thick at the base).
Is there a way to simplify the fin geometry? If anybody can give me an advise I will appreciate it.
Kind regards,
egge24 is offline   Reply With Quote
Trackbacks are On
[ANSYS Meshing] only automatic meshing works, kazra ANSYS Meshing & Geometry 2 February 23, 2017 11:38
Meshing Process sidharth9426 STAR-CCM+ 4 September 15, 2015 03:31
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 14:27
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
