[ANSYS Meshing] Negative elements along helix with triangular cross section |
August 1, 2019, 10:34 |
Rep Power: 6 |
I am trying mesh a helical channel with triangular cross section, when I apply the mesh features to a much shorter section of the channel it works fine, when i try this on a full length channel i start to get negative elements at points along the rounded corners. I'm using a boundary layer refinement for a K-w SST turbulence model Please let me know if there are any files i can send for inspection Rob |
August 1, 2019, 15:02 |
Erik
Rep Power: 23 |
Try sweep mesh.
or Slice body as shown to create mapped sweepable bodies, then create part. Use sweep mesh with all quads from one end to the other. |
[ANSYS Meshing] error:Zero or negative volume for elements. | zhizhuo | ANSYS Meshing & Geometry | 0 | November 27, 2017 06:25 |
[DesignModeler] Activate cross section to select radius item | Ben_15 | ANSYS Meshing & Geometry | 0 | March 12, 2017 06:47 |
flow in a nozzle with two narrowed cross section | whitecat | FLUENT | 0 | November 17, 2014 09:00 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
