[DesignModeler] Suction Pipe Submerged In Water Tank |
May 30, 2019, 17:46 |
Ross Toal
apologies for the assumingly trivial question, but I'm strangely having a difficult time finding out how to solve this problem. It's been a long day of nonstop CFDing and this one little problem is just making my brain go I'm trying to model a suction pipe for a tank of water. The pipe is vertical with a 90 degree bend to horizontal to where it exits the tank (as illustrated in the first picture). I haven't come across this scenario before, because any similar scenario tends to be a "T-junction" (where the pipe meets the wall, but not protrudes in. As shown in the second image). How do I make it so the pipe wall is a separate entity to the tanks internal fluid domain but allow flow through the pipe? Thanks in advance! * The first picture isn't a tutorial unfortunately and anything similar online is for 2D models" |
July 20, 2019, 10:03 |
make two parts , differently name it and give form new part
August 21, 2019, 10:25 |
#3 | |
Victor Ameno Cautela
Rep Power: 6 |
Can you please share with me the 2D tutorial?? Im trying to do a similar simulation, but having trouble in modeling.. Thank you very much! vcautela. |
January 16, 2020, 21:49 |
Pump Sump Vortex Check Simulation
Michael Jeremy
Rep Power: 6 |
hi im trying to simulate the fluid flow for a pump suction submerged in water tank but currently i couldnt get my result do to convergence issue. i confuse how is the right geometry and setup for my case. i think the mesh is good with skewness less than 0.8 and minimum orthogonal quality is larger than 0.2. im currently using transient k-epsilon turbulent with PISO pressure-velocity coupling. can somebody tell me the best geometry and setup ?
January 16, 2020, 21:56 |
Svetlana Tkachenko
Rep Power: 14 |
1. Does it converge for a while but then stop before reaching your convergence criteria? Or does it diverge? 2. What is the geometry and boundary conditions?
January 16, 2020, 22:05 |
Michael Jeremy
Rep Power: 6 |
its diverge. i will attach my geometry profile. the inlet velocity is 0.4 m/s with pressure around 50 kPa and pressure outlet is with the amount of 28 kPa. i create another named selection to define the air inlet with inlet pressure is atmospheric.
coaxial jet flow into an open water tank | sreesha | FLUENT | 0 | January 26, 2017 14:29 |
Mixture and Decay of a tracer in a Water Tank | Jeffrey1992 | CFX | 2 | July 27, 2012 13:31 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
