[Workbench] Mesh update error during parameter analysis in Ansys
Old   June 11, 2019, 08:00
Question Mesh update error during parameter analysis in Ansys
u_k
u_k is on a distinguished road
Hello Everyone,
During parametric study of my pipe geometry with (venturi inside) i have given set of new values of venturi dia to study the pressure drop behavior. But when the design point is sent from design modeler to ICEM, it failes to update and gives an error: "Update failed for the model component in ICEM CFD".
Does anyone have any idea why is it coming so??.....
u_k is offline   Reply With Quote
Old   June 11, 2019, 16:49
Anup Jain
jainanup27 is on a distinguished road
Originally Posted by u_k View Post
Hello Everyone,
I am facing the same exact problem for other geometry. In the progress tab you can see where it is giving this error. It might be giving at Loding Mesh and Model Information.
It might be that is because of the mesh. Just run your simulation for one design point and see if the mesh is correct. In my case I see that due to change in geometry the mesh changes however, the blocking remains the same and hence I have overlapping edges. Can you check that for your case as well?
Thanks,
jainanup27 is offline   Reply With Quote
Trackbacks are On
Hydrodynamic analysis of submarine model with ANSYS FLUENT? Sovereignty ANSYS 0 January 20, 2019 18:36
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 12:07
ICEM of ANSYS V15: how to export .msh mesh for CFX hydroaero CFX 1 March 9, 2015 22:15
[ANSYS Meshing] modal analysis by ansys using existing mesh hityangsir ANSYS Meshing & Geometry 0 March 5, 2014 01:08
ansys imports icem-cfd ansys mesh adam2008 ANSYS Meshing & Geometry 0 March 5, 2011 08:40
