shroud clearance from bladegen to blade editor(geometry)
Hi guys,
despite imposing the clearance to the correct layer, the geometry is blocking the importing procedure because of error related to the presence of clearance, I am saying this because otherwise the system is importing correctly the geometry from bladegen in design modeller. The clearance if and only if I import geometry directly in turbogrid I need blade editor to modify some features of the fluid domain somebody has some suggestions? thank you |
