September 6, 2019, 03:41 |
Bad elements in fine boundary layer
Rep Power: 6 |
Hello everyone,
I have a problem with inflation layers on an o-gird. My mesh quality without inflation layers is pretty decent. Talking about determinant higher than 0.8, angles higher than 30. The O-grid is a single outer o-grid of a cylinder. The cylinder itself is not part of the Domain so the block got deleted after the creation of the outer o-grid. Now I need to add inflation layers to the surface of the cylinder with a pretty narrow first cell height of 0.001mm. The following pre-mesh Parameters are applied: Maximum size: 0.1 Height: 0.001 Height ratio: 1.2 Num layers: 20 Tetra size ratio: 1.2 Now I get negative cells in the boundary layer. I already tried to decrease the triangulation tolerance which does not seem to do anything at all and I also already activated the "set to bsplines" option in the hexa mesh setup which also does not solve the issue. I really don't know what the problem is, so maybe you can help me out with that. I appreciate your help! Best regards! |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh | mike.franky | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2018 09:46 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
